IOLITE TH-HS MiniTC connector pinout
AL
Alessia Longo
AH
Al Hoge
BJ
Bernard Jerman
Bojan Čontala
CS
Carsten Stjernfelt
DC
Daniel Colmenares
DF
Dino Florjančič
EB
Emanuele Burgognoni
FB
Franck Beranger
GR
GC
HB
Helmut Behmüller
IB
Iza Burnik
JO
Jaka Ogorevc
JR
Jake Rosenthal
JS
Jernej Sirk
JM
John Miller
KM
Karla Yera Morales
KD
Kayla Day
KS
LW
LS
Loïc Siret
LJ
Luka Jerman
MB
Marco Behmer
MR
Marco Ribichini
MS
ME
Matthew Engquist
ME
Michael Elmerick
NP
Nicolas Phan
OM
Owen Maginity
PF
Patrick Fu
RM
RS
Rupert Schwarz
SA
Samuele Ardizio
SK
Simon Kodrič
SG
Søren Linnet Gjelstrup
TH
Thorsten Hartleb
TV
Tirin Varghese
UK
Urban Kuhar
VP
VS
Vid Selič
WK
Will Kooiker
New IOLITE TH-HS Module - Universal High-Speed Thermocouple Input
IOLITE 8xTH-HS
The IOLITEir-8xTH-HS is a new version of the 8-channel IOLITE thermocouple temperature module. It is a channel-to-channel isolated DAQ device for thermocouple temperature measurements using universal thermocouple inputs: K, J, T, R, S, N, E, C, B.
IOLITE 8xTH-HS
The main purpose of this device is to address the growing need for stable temperature measurements in an EMC harsh environment, e.g. on the stator of an electric motor or near inverters. The new module not only improves the EMC immunity of the previous unit on the digital side but also utilizes a sharp analog antialiasing filter (3rd order, -3dB @ 1kHz) and digital FIR filters to remove unwanted frequencies.
The input connector of the module is MINI TC for the universal thermocouple type. It offers sensor break detection in the software and applies physical LED indicators.
The module uses a new 24-bit ADC with sampling rates up to 10 kS/s per channel. This enables IOLITEir-8xTH-HS to be used in the dynamically most demanding applications to record transients of temperature shock.
A higher sampling rate enables Dewesoft filtering technology using digital FIR filters to reduce noise floor down to -130 dB and reach a resolution of less than 1 μK.
The IOLITE TH-HS module will be sold in parallel with the current IOLITE TH modules until the existing IOLITE TH modules run out of stock.
The TH-HS module will be sold at the same price as IOLITE TH for the sampling at 100 S/s and as an option for10 kS/s sampling speed.
As all IOLITE standard modules, also IOLITEir-8xTH-HS is equipped with two EtherCAT buses in parallel for both DAQ and real-time control. It can be mounted either in rack chassis (IOLITE-R12, IOLITE-R8, IOLITE-R8r, or IOLITE-LX-R8 chassis).
IOLITE TH HS-mini tc connector pinout
Ioliteir 8xTH-HS front panel
PinNameDescription
1In+Input +
2In-Input -
IOLITE TH-HS technical specifications
To check full IOLITE TH-HS amplifier specifications and accuracy please visit the IOLITE technical specification webpage.
