Product Updates
Introducing IOLITEir-8xRTDp
The IOLITEir-8xRTDp is an 8-channel temperature module for cryogenic environments using resistance temperature detectors (RTD). Through pulsed excitation and AC coupling, it eliminates DC offset errors caused by the Seebeck effect, ensuring accurate temperature readings. The module supports up to 100 S/s per channel, integrates with DewesoftX and real-time control systems via dual EtherCAT buses, and is compatible with standard IOLITE rack chassis.
