ALAlessia Longo
AHAl Hoge
BJBernard Jerman
BČBojan Čontala
CFCarsten Frederiksen
CSCarsten Stjernfelt
DCDaniel Colmenares
DFDino Florjančič
EBEmanuele Burgognoni
EKEva Kalšek
FBFranck Beranger
GRGabriele Ribichini
GSGrant Maloy Smith
HBHelmut Behmüller
IBIza Burnik
JOJaka Ogorevc
JRJake Rosenthal
JSJernej Sirk
JMJohn Miller
KMKarla Yera Morales
KDKayla Day
KSKonrad Schweiger
LSLoïc Siret
LJLuka Jerman
MBMarco Behmer
MRMarco Ribichini
MLMatic Lebar
MSMatjaž Strniša
MEMatthew Engquist
MEMichael Elmerick
NPNicolas Phan
OMOwen Maginity
PFPatrick Fu
PRPrimož Rome
RMRok Mesar
RSRupert Schwarz
SASamuele Ardizio
SKSimon Kodrič
SGSøren Linnet Gjelstrup
THThorsten Hartleb
TVTirin Varghese
UKUrban Kuhar
VSVid Selič
WKWill Kooiker
New DSI Adapters for Thermocouple Type E and Current Measurement
February 20, 2023
We are announcing the release of the new DSI adapters:
DSI-TH-E: Thermocouple type E adapter for temperature measurement
DSI-5A: Revised current measurement adapter up to 5A
The versatile Dewesoft DSI® adapters convert any Dewesoft's DAQ system analog input amplifiers with DSUB9 connector into a universal analog input that can accept everything from strain gage, IEPE/ICP, thermocouple, LVDT, RTD, current to voltage signals with up to ±200V.
DSI adapters are automatically recognized by the TEDS sensor chip (IEEE 1451.4) and all settings are configured automatically inside Dewesoft X DAQ software.
DSI-TH-E - thermocouple type E adapter for temperature measurement
DSI-TH-E is the latest edition to the DSI® thermocouple adapters product range. DSI-TH-E is designed for type E thermocouple.
Type E thermocouple has the highest sensitivity in terms of mV/K. It is operating in a temperature range between -270 °C and 1000 °C.
Host amplifier configuration and calibration coefficients can be read via TEDS.
Host amplifier compatibility and specs
DSI-TH-E for thermocouple type E (DIN EN 60584-1)
| DAQ hardware | SIRIUS LVSIRIUS STGSIRIUS HD-STGS | SIRIUSi XHS-LVKRYPTONi STGIOLITE STG | SIRIUS STGMMINITAURs | DEWE-43ASIRIUSi HD-LV | SIRIUSi HS-LV | SIRIUSi HS-STG | SIRIUSi MULTI | |
| Input Range | Actual reading | Typical accuracy [maximum accuracy] | ||||||
| -270 to 1000 °C | -250 to -200 °C | ±2.3 [±10.2] °C | ±6.5 [±11.8] °C | ±3.2 [±10.2] °C | ±5.8 [±10.2] °C | ±1.7 [±11.8] °C | ±1.7 [±5.6] °C | ±3.2 [±19.0] °C |
| -200 to -100 °C | ±1.5 [±5.0] °C | ±3.4 [±5.6] °C | ±1.9 [±5.0] °C | ±3.1 [±5.0] °C | ±1.3 [±5.6] °C | ±1.3 [±3.0] °C | ±1.9 [±8.7] °C | |
| -100 to 0 °C | ±1.3 [±3.2] °C | ±2.3 [±3.6] °C | ±1.5 [±3.2] °C | ±2.1 [±3.2] °C | ±1.1 [±3.6] °C | ±1.1 [±2.1] °C | ±1.5 [±5.4] °C | |
| 0 to 500 °C | ±1.3 [±2.4] °C | ±1.9 [±2.6] °C | ±1.4 [±2.4] °C | ±1.8 [±2.4] °C | ±1.2 [±2.6] °C | ±1.2 [±1.7] °C | ±1.4 [±3.7] °C | |
| 500 to 1000 °C | ±1.6 [±2.8] °C | ±2.1 [±2.9] °C | ±1.8 [±2.8] °C | ±2.2 [±2.8] °C | ±1.4 [±2.9] °C | ±1.4 [±2.0] °C | ±1.8 [±4.2] °C |
DSI-5A - current measurement adapter
Same on the outside, new on the inside. DSI-5A v2 is the new version of DSI® adapters allowing current measurements up to 5 A.
The motivation for the new version was the discontinuation of the shunt resistor.
DSI-5A v2 still contains a 10 mΩ shunt resistor with 0.1% accuracy when calibrated. Significant improvement is in temperature stability. The new shunt resistor has two-times better temperature coefficient (now 15 ppm/K over the range -55 °C to +125 °C, before 30 ppm/K over the range -20 °C to +60 °C).
Input connector of the DSI-5A adapter is the same 3-pin screw terminal where you can connect wires with the nominal cross-section up to 2.5 mm².
DSI-5A connector pinout
| Pin | Name | Description |
| 1 | IN + | Current Input - |
| 2 | IN - | Current Input + |
| 3 | GND | Analog ground |
Learn more:
