ALAlessia Longo
AHAl Hoge
ABAljaž Blažun
BJBernard Jerman
BČBojan Čontala
CFCarsten Frederiksen
CSCarsten Stjernfelt
DCDaniel Colmenares
DFDino Florjančič
EBEmanuele Burgognoni
EKEva Kalšek
FBFranck Beranger
GRGabriele Ribichini
GSGrant Maloy Smith
HBHelmut Behmüller
IBIza Burnik
JOJaka Ogorevc
JRJake Rosenthal
JSJernej Sirk
JMJohn Miller
KMKarla Yera Morales
KDKayla Day
KSKonrad Schweiger
LSLoïc Siret
LJLuka Jerman
MBMarco Behmer
MRMarco Ribichini
MLMatic Lebar
MSMatjaž Strniša
MEMatthew Engquist
MEMichael Elmerick
NPNicolas Phan
OMOwen Maginity
PFPatrick Fu
PRPrimož Rome
RMRok Mesar
RSRupert Schwarz
SASamuele Ardizio
SKSimon Kodrič
SGSøren Linnet Gjelstrup
THThorsten Hartleb
TVTirin Varghese
UKUrban Kuhar
VSVid Selič
WKWill Kooiker
Introducing IOLITEir-8xRTDp
June 11, 2025
The IOLITEir-8xRTDp is a new version of the 8-channel IOLITE temperature module. It is a channel-to-channel isolated DAQ device especially suitable for cryogenic temperature measurements using resistance temperature detectors (RTD).
In extremely low-temperature environments, such as cooling applications with liquid nitrogen, the Seebeck effect is often unavoidable. The phenomenon produces a voltage difference when the two conductors have a large temperature difference, in this case, the sensor and the measurement device. The generated voltage adds an error to the measurement. The IOLITEir-8xRTDp eliminates this DC offset error by using pulsed excitation, creating an AC coupling and, therefore, ensuring the accuracy of the temperature reading.
The standard, DC excitation type is also available on the module as well as a voltage input mode with ranges of ±1 V and ±100 mV. The excitation mode (DC or AC) can be configured individually for each channel using the software. The input connector of the IOLITEir-8xRTDp is 6-pin 0B Series Lemo connector and the module uses a 24-bit ADC with sampling rates up to 100 S/s per channel.
As with all standard IOLITE modules, the IOLITEir-8xRTDp is equipped with two EtherCAT buses, making it suitable for collecting data via DewesoftX while providing it to a real-time control system in parallel. It can be mounted in all standard rack chassis (IOLITE-R12, IOLITE-R8, IOLITE-R8r).
