ALAlessia Longo
AHAl Hoge
ABAljaž Blažun
BJBernard Jerman
BČBojan Čontala
CFCarsten Frederiksen
CSCarsten Stjernfelt
DCDaniel Colmenares
DFDino Florjančič
EBEmanuele Burgognoni
EKEva Kalšek
FBFranck Beranger
GRGabriele Ribichini
GSGrant Maloy Smith
HBHelmut Behmüller
IBIza Burnik
JOJaka Ogorevc
JRJake Rosenthal
JSJernej Sirk
JMJohn Miller
KMKarla Yera Morales
KDKayla Day
KSKonrad Schweiger
LSLoïc Siret
LJLuka Jerman
MBMarco Behmer
MRMarco Ribichini
MLMatic Lebar
MSMatjaž Strniša
MEMatthew Engquist
MEMichael Elmerick
NPNicolas Phan
OMOwen Maginity
PFPatrick Fu
PRPrimož Rome
RMRok Mesar
RSRupert Schwarz
SASamuele Ardizio
SKSimon Kodrič
SGSøren Linnet Gjelstrup
THThorsten Hartleb
TVTirin Varghese
UKUrban Kuhar
VSVid Selič
WKWill Kooiker
VIB-ISO-BASE: Vibration Isolation Rack for SIRIUS and SBOX Waterproof
February 15, 2023
The Vibration Isolation Rack (VIB-ISO-BASE) expands the operation range of the EtherCAT® SIRIUS waterproof data acquisition systems and SBOX waterproof processing computer to tackle the high vibration environments. The VIB-ISO-BASE is designed with the help of our in-house vibration shaker and the Dewesoft Modal Test module.
Introduction
Machines with moving parts normally produce some form of vibration. Usually, these vibrations have lower magnitudes which don’t affect the lifetime of electronics in measurement instruments. However, on machines that produce vibrations of higher magnitudes during operation (pneumatic hammers, vibratory separators…) the lifetime of electronics can be significantly reduced. Without a considerable redesign of electronics, instruments can only be used in such environments if the electronic boards are enclosed in rubber or are isolated from the outside vibration by some form of a damping system.
Isolation mount
We opted for the second option – isolating SIRIUS waterproof data acquisition systems from outside vibration. We developed a mounting mechanism that isolates the instruments by suspending them on four rubber dampers. The mounting mechanism was finalized after three testing-redesign iterations.
Mounts were tested under a random vibration specified by the power spectral density (PSD).
Tests were performed on an in-house shaker, covering all three directions. The isolation effectivity was evaluated by acceleration measurements on the instruments and different parts of the mount. A SIRIUS DAQ system with ACC amplifiers acquired the data, calculating the Dewesoft Modal Test mathematics in real-time. In this way, the isolation performance was evaluated in a couple of minutes.
The VIB-ISO-BASE has a low natural frequency, where the excitation vibrations are amplified (around 30 Hz depending on the excitation direction). All of the vibration frequencies higher than that are dampened by the mount. It is especially effective at higher frequencies which are more harmful to electronic components. The instrument acceleration amplitudes are at least fourteen times lower than the excitation amplitudes at frequencies above 1000 Hz.
The durability of the mounts and instruments was also tested in all three directions, while continuously storing measurement data.
Instrument rack
The developed isolation mounts were incorporated in a robust instrument rack that can house SIRIUS waterproof or SBOX waterproof instruments. The instrument rack can successfully sustain the vibrations in any direction, it provides the same isolation to the units as the developed isolation mount.
The VIB-ISO-BASE rack can house one or two instruments and can be extended to house up to four SIRIUSwe instruments by using the VIB-ISO-EXTENDER. The rack is bolted or strapped to remain fixed.
VIB-ISO and VIB-ISO-EXTENDER are now available to buy as an accessory to the SIRIUSwe line of data acquisition instruments.
