Alessia Longo
Al Hoge
Bernard Jerman
Bojan Čontala
Carsten Stjernfelt
Daniel Colmenares
Dino Florjančič
Emanuele Burgognoni
Franck Beranger
Helmut Behmüller
Iza Burnik
Jaka Ogorevc
Jake Rosenthal
Jernej Sirk
John Miller
Karla Yera Morales
Kayla Day
Loïc Siret
Luka Jerman
Marco Behmer
Marco Ribichini
Matthew Engquist
Michael Elmerick
Nicolas Phan
Owen Maginity
Patrick Fu
Rupert Schwarz
Samuele Ardizio
Simon Kodrič
Søren Linnet Gjelstrup
Thorsten Hartleb
Tirin Varghese
Urban Kuhar
Vid Selič
Will Kooiker
RTD temperature measurement module for IOLITE DAQ system
March 3, 2023
IOLITEi-8xRTD is the latest module in the IOLITE data acquisition family. IOLITEi-8xRTD is an 8-channel module for temperature measurement with resistance temperature detectors (RTD). It can be also used for resistance measurements with ranges up to 10 kΩ and voltage measurements with ranges up to 1 V.
The RTD module supports practically all resistance thermometers, from standard platinum resistance thermometers - PRT. Supported types are:
Pt100,
Pt200,
Pt500,
Pt1000,
Pt2000
to fast responsive thermistor sensors.
RTD module offers both channel-to-ground as well as channel-to-channel isolation up to 1000 V. With the RTD module the data are acquired simultaneously from all 8 channels with sampling rates up to 100 samples per second using 24-bit delta-sigma ADC.
The input connector of 8xRTD is a Lemo 0B 6-pin (EEA.0B.306.CLN).
IOLITEi-8xRTD can be mounted, as all IOLITE modules, in rugged IOLITE R8 chassis or in an industry-standard IOLITE R12 19” rack cabinet compatible chassis.
IOLITEi-8xRTD is the right choice for the most accurate temperature measurements in industrial applications.
The modules are compatible with all IOLITE chassis and system options:
IOLITE is perfect for Industry 4.0 automation, automotive test benches, aerospace component testing, structural monitoring, and alarming - just to name a few applications.
