IOLITE-16xLV
AL
Alessia Longo
AH
Al Hoge
AB
Aljaž Blažun
BJ
Bernard Jerman
Bojan Čontala
CS
Carsten Stjernfelt
DC
Daniel Colmenares
DF
Dino Florjančič
EB
Emanuele Burgognoni
FB
Franck Beranger
GR
GC
HB
Helmut Behmüller
IB
Iza Burnik
JO
Jaka Ogorevc
JR
Jake Rosenthal
JS
Jernej Sirk
JM
John Miller
KM
Karla Yera Morales
KD
Kayla Day
KS
LW
LS
Loïc Siret
LJ
Luka Jerman
MB
Marco Behmer
MR
Marco Ribichini
MS
ME
Matthew Engquist
ME
Michael Elmerick
NP
Nicolas Phan
OM
Owen Maginity
PF
Patrick Fu
RM
RS
Rupert Schwarz
SA
Samuele Ardizio
SK
Simon Kodrič
SG
Søren Linnet Gjelstrup
TH
Thorsten Hartleb
TV
Tirin Varghese
UK
Urban Kuhar
VP
VS
Vid Selič
WK
Will Kooiker
New IOLITE® Modular Amplifier Modules
JO
Jaka Ogorevc
September 26, 2025
IOLITE modular amplifier modules
When you need to have your DAQ system as close as possible to the sensor, this new line of distributable multi-channel IOLITE systems is the way to go. As of today, the following modules are available in the IOLITE modular product range:
  • IOLITE-16xLV
  • IOLITE-8xLVe
  • IOLITE-8xSTGS
  • IOLITEi-8xTH-HS
  • IOLITEi-RTD-HS
A great feature of these new IOLITE modules is passive PoE (power over Ethernet), allowing you to daisy chain several IOLITE modular units with just a network cable. Since the power is "always on" when using a passive PoE we recommend the connection to the PC as shown below:
Power over Ethernet
This also enables easy connection to IOLITE single units:
Easy connection to IOLITE single units
The upgraded power supply of the IOLITE multi-standalone products also offers a power injector feature that can prevent voltage drops caused by long cables.
Upgraded power supply of the IOLITE multi standalone products
The bundle addresses the growing need for stable temperature measurements in challenging EMC environments. IOLITE is a great solution for industrial low voltage measurement applications. This product series also offers a TEDS-compatible strain gauge module with low power consumption and long-term stability.
The specifications of these modules are the same as their rack versions.
IOLITE-16xLV
16-channel voltage input module. Selectable ±200 V and ±10 V input ranges, 24-bit oversampled sigma-delta ADC.
IOLITE-16xLV
IOLITE-8xLVe
8-channel low voltage and industrial sensor module. Includes unipolar excitation and TEDS support. More than just a voltage module, the 8xLVe works with a variety of industrial sensors including pressure sensors, potentiometers and MEMS accelerometers. Due to its powerful sensor supply, it is also compatible with certain current sensors.
IOLITE-8xLVe
IOLITE-8xLVe-D37
IOLITE-8xSTGS
8-channel strain gauge module. Supports full, half, and quarter bridge configurations, as well as potentiometer mode. Selectable bridge ranges of 2 mV/V, 20 mV/V, 200 mV/V, with selectable 1, 2 or 5 V excitation and a built-in 100 kΩ shunt. includes TEDS sensor identification support. Available with either DSUB-37 or terminal block connectors.
IOLITE-8xSTGS
IOLITE-8xSTGS-D37
IOLITEi-8xTH-HS
8-channel high-speed thermocouple module. Includes a new 24-bit ADC with sample rates of up to 10 kS/s per channel, channel-to-channel isolation, improved EMC immunity via a sharp analog anti-aliasing filter (third order, -3dB @ 1kHz) and digital FIR filters.
IOLITEi-8xTH-HS
IOLITEi-8xRTD-HS
8-channel high-speed RTD module. Includes a new 24-bit ADC with sample rates up to 10 kS/s per channel, channel-to-channel isolation, improved EMC immunity via a sharp analog anti-aliasing filter (-130 dB, less than 1 mK resolution), available with either terminal block or LEMO connectors.
IOLITEi-8xRTD-HS-T2A4f
More information and technical specifications
IOLITE Modlar data acquisition devices (DAQ)IOLITE® ModularModular Industrial Data Acquisition (DAQ) Systems
