Introduction
AL
Alessia Longo
AH
Al Hoge
AB
Aljaž Blažun
BJ
Bernard Jerman
Bojan Čontala
CS
Carsten Stjernfelt
DC
Daniel Colmenares
DF
Dino Florjančič
EB
Emanuele Burgognoni
FB
Franck Beranger
GR
GC
HB
Helmut Behmüller
IB
Iza Burnik
JO
Jaka Ogorevc
JR
Jake Rosenthal
JS
Jernej Sirk
JM
John Miller
KM
Karla Yera Morales
KD
Kayla Day
KS
LW
LS
Loïc Siret
LJ
Luka Jerman
MB
Marco Behmer
MR
Marco Ribichini
MS
ME
Matthew Engquist
ME
Michael Elmerick
NP
Nicolas Phan
OM
Owen Maginity
PF
Patrick Fu
RM
RS
Rupert Schwarz
SA
Samuele Ardizio
SK
Simon Kodrič
SG
Søren Linnet Gjelstrup
TH
Thorsten Hartleb
TV
Tirin Varghese
UK
Urban Kuhar
VP
VS
Vid Selič
WK
Will Kooiker
ISO Lane-Change Manoeuvre Test (ISO 3888)
This application note shows how Dewesoft products provide an effective and flexible solution for quick validation and measurement of ISO lane-change test (ISO 3888). The mobile measurement instruments and the easy-to-setup software are used for checking and visualization of measured parameters to guide the driver through the measurement and check the results online.
DewesoftX measurement screen
Introduction
The client, a car manufacturer in Italy, designing, testing and manufacturing different vehicles including cars asked for help at shorting time of testing and improving quality of results at vehicle dynamic maneuvers, which includes online check of results and gives direct feedback to the driver either if the test was successful or they have to repeat it.
ISO lane change
One of such maneuvers is the double lane change maneuver, which is used worldwide to evaluate the handling and safety of vehicles and their key components. Therefore various parameters are being checked by the test engineer, but for a driver it’s crucial, to have an online check if the test has passed or failed (cones were hit or not). Tested with pure GNSS device and combination of GNSS with AHRS, to compare results.
Measurement setup
Data acquisition system
  • DEWE-43 compact, mobile data acquisition system with universal analog inputs, counter/encoder/digital inputs and CAN bus inputs
Sensors
  • DS-IMU2 inertial measurement unit with RTK upgrade ->1 cm accuracy
  • DS-RTK-BASE (GPS based unit) to provide RTK accuracy for vehicle
Software
DS IMU GPS setup
Polygon setup
Polygon objects (fixed and moving cones) have been set up according to the ISO 3888 standard. The advantage of using moving cones is that the driver can quickly change the car and edit vehicles length/width. With having those parameters, the configuration of the maneuver is changed according to the standard (width of the track,..).
DewesoftX polygon setup
Several additional calculations have been added to evaluate different parameters (like velocity, roll,..) versus distance on the track, which is shown in results.
By having certain lines as Start and Stop trigger, it is possible to reduce the file size and capture only the points of interest.
Analysis
Measurement screen combined together with analysis for online checking
The display below is included in a Lane Change setup. It shows online validation of the data, so the driver has direct feedback if the test has passed or failed, which is located in the top left of the screen. The 2D display shows the graph of velocity during the track (Velocity/PosX on the track). At the same time, it’s also possible to display the graph of PosY/PosX, to see the lane change maneuver.
In addition, we were measuring the vehicle CAN bus to have information on RPM, steering angle and other vital analysis parameters.
The measurement with DS-IMU2 with 1 cm RTK upgrade has shown a very accurate position (centimeter level) and 3-axis velocity results. Due to this it can be used for regulation and going even further due to the inertial platform it can be used also for research and development, where additional parameters as Roll, Angular velocity in Z-axis and Ay for evaluation of vehicle handling are needed.
After teaching the drivers and performing several tests, with different cars, time of testing, in comparison with setting manual cones and measure complete track every time, has been reduced for at least 30%, which is a great improvement.
