Supported Scanivalve models
AL
Alessia Longo
AH
Al Hoge
BJ
Bernard Jerman
Bojan Čontala
CS
Carsten Stjernfelt
DC
Daniel Colmenares
DF
Dino Florjančič
EB
Emanuele Burgognoni
FB
Franck Beranger
GR
GC
HB
Helmut Behmüller
IB
Iza Burnik
JO
Jaka Ogorevc
JR
Jake Rosenthal
JS
Jernej Sirk
JM
John Miller
KM
Karla Yera Morales
KD
Kayla Day
KS
LW
LS
Loïc Siret
LJ
Luka Jerman
MB
Marco Behmer
MR
Marco Ribichini
MS
ME
Matthew Engquist
ME
Michael Elmerick
NP
Nicolas Phan
OM
Owen Maginity
PF
Patrick Fu
RM
RS
Rupert Schwarz
SA
Samuele Ardizio
SK
Simon Kodrič
SG
Søren Linnet Gjelstrup
TH
Thorsten Hartleb
TV
Tirin Varghese
UK
Urban Kuhar
VP
VS
Vid Selič
WK
Will Kooiker
Integrating Scanivalve Pressure Scanners with Dewesoft DAQ Systems
ME
Michael Elmerick
February 6, 2025
Scanivalve is a leading manufacturer of intelligent Ethernet pressure scanners known for its high-channel-count devices, built-in analog-to-digital conversion, and real-time data streaming capabilities. To facilitate seamless integration, Dewesoft has developed a specialized DewesoftX plugin that supports several Scanivalve pressure scanner models, including the DSA-5000, MPS-4264, and legacy DSA-3217-PTP.
Direct Ethernet connection between Scanivalve DSA-5000 and a Windows computer running DewesoftX DAQ software.
Left to right: Scanivalve models DSA-5000, MPS-4264, and DSA-3217-PTP
With our user-friendly plugin, DewesoftX software supports one or more Scanivalve modules. Their built-in Ethernet interfaces allow direct connections to your PC or via a network switch, offering flexible setup options.
Connecting Scanivalve to your Dewesoft DAQ system
The setup begins by physically connecting the Scanivalve pressure scanners to your DAQ system. You can connect the devices directly to your PC’s Ethernet port or through an Ethernet switch, as shown below:
Multiple Scanivalve devices are connected to the DAQ computer via an unmanaged Ethernet switch.
Software configuration
After connecting the hardware, install the necessary software license and configure the devices within DewesoftX. Follow these steps:
  1. Add Devices in Project Settings. Open the project settings in DewesoftX, select "Add Device," and input the details for each Scanivalve unit.
Left: Adding a device in project settings. Right: Project devices with Scanivalve devices added and configured
  1. Configure Device Parameters. Enter the model numbers and IP addresses for all connected Scanivalve devices. Once configured, their status will change to "connected."
  2. Access Channel Settings. Once connected, a new icon will appear on the DewesoftX taskbar. Click it to open the channel setup screen for all connected Scanivalve devices.
  3. Enter the license. Enter the software license after connecting one or more Scanivalves to your DAQ system computer.
Close the project settings, and a new icon will appear on the taskbar near the top of the DewesoftX setup screen, as shown in the figure below:
The Scanivalve icon in the DewesoftX taskbar.
Clicking this icon opens the channel settings for all connected Scanivalve devices. Here, you can select the channels you want to use in your setup, rename them, assign specific colors to each channel, change the engineering units and each unit's sample rate, and send the CAL Z command to the unit to perform an internal zeroing calibration.
Scanivalve Channel Setup Screen
Channel configuration options
The channel setup screen allows you to:
  • Select and rename channels.
  • Assign specific colors to each channel.
  • Adjust engineering units and acquisition rates.
  • Send the CAL Z command for internal zeroing calibration.
Once the configuration is complete, pressure data can be displayed, stored, and analyzed in DewesoftX alongside other analog and digital channels.
Scanivalve pressure measurement
Integrating Scanivalve’s unique Ethernet-connected pressure scanners with DewesoftX DAQ software adds value to any measurement system. Scanivalve pressure scanners are used for pressure and temperature measurement, especially for aerospace and automotive aerodynamic tests, gas turbine testing, compressor testing, and other turbomachinery tests, flow measurement across an orifice, wind turbine aerodynamic validations, etc.
DewesoftX software comes with every Dewesoft DAQ system. Besides the Scanivalve hardware, only the software plugin described here is required. You can order the Scanivalve plugin from the Dewesoft website. A user manual is available on our website and in the local help manual installed with DewesoftX.
Learn more about the Scanivalve DewesoftX software module.
Learn more about Scanivalve pressure sensors.
