ALAlessia Longo
AHAl Hoge
ABAljaž Blažun
BJBernard Jerman
BČBojan Čontala
CFCarsten Frederiksen
CSCarsten Stjernfelt
DCDaniel Colmenares
DFDino Florjančič
EBEmanuele Burgognoni
EKEva Kalšek
FBFranck Beranger
GRGabriele Ribichini
GSGrant Maloy Smith
HBHelmut Behmüller
IBIza Burnik
JOJaka Ogorevc
JRJake Rosenthal
JSJernej Sirk
JMJohn Miller
KMKarla Yera Morales
KDKayla Day
KSKonrad Schweiger
LSLoïc Siret
LJLuka Jerman
MBMarco Behmer
MRMarco Ribichini
MLMatic Lebar
MSMatjaž Strniša
MEMatthew Engquist
MEMichael Elmerick
NPNicolas Phan
OMOwen Maginity
PFPatrick Fu
PRPrimož Rome
RMRok Mesar
RSRupert Schwarz
SASamuele Ardizio
SKSimon Kodrič
SGSøren Linnet Gjelstrup
THThorsten Hartleb
TVTirin Varghese
UKUrban Kuhar
VSVid Selič
WKWill Kooiker
Construction Noise and Vibration Monitoring
Construction noise and vibration can be a nuisance to the neighboring community. Most often the builder has to comply with regulations defining threshold levels and limiting working hours. The consulting company ACTS set up a Dewesoft monitoring system during the construction of the large complex of Abu Dhabi Global Market to ensure there wasn't excessive sound or vibration due to the ongoing construction.
Abu Dhabi Global Market (ADGM) is a financial center and a free zone located on Al Maryah Island in the heart of the UAE's capital city, Abu Dhabi. Finalized in 2018 the structure under investigation extending across the entire 114 hectares of the island, now houses an international arbitration hearing center and is part of a large complex of buildings established by the Abu Dhabi Chamber of Commerce in 2013.
According to Abu Dhabi’s Environment Health and Safety Management System, any activity resulting in excess noise that can harm the peace of a neighbourhood should be undertaken only between 7 am and 8 pm on working days, and between 9 am and 7 pm on weekends and public holidays unless developers have a special license from the municipality.
Noise pollution is defined as the “excessive, upsetting human, animal or machine-created environmental noise that disrupts the activity, balance or harmony of normal life".
In this case, the monitoring was carried out by ACTS, Advanced Construction Technology, Services on behalf of the customer. ACTS provides construction consultancy services specializing in the materials and geoengineering fields. ACTS currently operates throughout the Middle East, Africa, and Southeast Asia, headquartered in Beirut, Lebanon, and with a local office in Dubai.
The project scope was to check if the noise or vibration were excessive due to the ongoing construction. The consulting company set the threshold limits:
the noise level and
RMS acceleration value.
One of the goals was to evaluate the results any time the values passed these limits. This monitoring station enabled them to take initiative to avoid getting into the high-level zones too often, e.g. by applying dampers or noise barriers.
Below are the threshold that was used during the investigation:
High Average noise levels in the rating above 90 dBA.
Moderate Average noise levels are for recorded values between 70dBA and 90 dBA
Normal Average noise levels are for recorded values below 70dBA.
The RMS acceleration value limit was set to 80ug in all directions (X, Y, Z).
Measurement setup
To monitor the structure for vibration and sound levels, a state-of-the-art hardware device system was installed. The system includes the following:
1x data logging embedded PC
1x 24 V power supply (to power the PC)
1x IOLITE Power-Injector
1x 48 V power supply (to power the devices)
2x IOLITEi-1xACC (in aluminium waterproof boxes)
4x IOLITEiw-3xMEMS-ACC
2x GRAS 146AE microphone
To verify whether the ongoing works are affecting the surrounding of the building, the vibration and sound sensors were installed at different locations. The vibration was measured at four reinforced concrete columns while the sound levels were checked for two locations in the surrounding area.
Measurements
The consultants were monitoring the noise using the DAQ system and the microphones as a sound level meter - fulfilling the IEC 61672 requirements for Class I. The parameters measured were:
LAF peak - the peak the Sound Level with ‘A’ Frequency weighting and Fast Time weighting, and
LAF average over 1 min.
In LAF the “L” represents “Level”, the sound pressure level. The “A” represents the frequency weighting which indicates that some frequencies within the audio spectrum are given a weighting. The A-weighting is the standard weighting of the audible frequencies - the range from 20Hz to 20kHz - and reflects the sensitivity of the human ear to noise.
The IEC 61672-1 standard on sound level meters describes two-time types of weightings, Fast (F) and Slow (S). They both dampen the reaction of the displayed level to a sudden change in the sound level. Fast Time Weighting is generally the time weighting used for environmental noise measurements, where sound varies over time.
The Peak is the maximum pressure level value reached by the sound and is well-suited to measure impulsive sounds.
The vibration parameters used were:
Root Mean Square value (RMS), and
Peak-to-Peak (P-P).
The RMS value is the instantaneous values within a certain duration of time and relates to the power of the vibration. The RMS is generally a useful indicator to represent the vibration level in practice as it is directly related to the energy content of the vibration profile and thus the destructive capability of the vibration.
The peak-to-peak value has the benefit of providing the maximum excursion of the wave, which is useful when looking at displacement information.
The construction/demolition works started at around 7 am and were concluded at around 6 pm. The noise monitoring reports show that the highest LAF peak noise registered during the monitored period was 99dBA.
Overall, the vibration monitoring system did not detect any significant acceleration levels due to the construction works. However, a small earthquake was noted on the 31st of October 2020.
The consulting company was very satisfied with the system due to its plug-and-play functionality and ability for automatic report generation for the final customer.
With the help of the DewesoftX software threshold setting tool and notification system by SMS and e-mail, the final customer-managed through proper work planning, maintenance of machinery, the use of acoustic barriers, etc. to conduct the demolition and construction works respecting all the country noise and vibration standards.
The Dewesoft noise and vibration monitoring solution helped the client to finish the project on time without any increase in the project costs due to delays or potential nuisance claims.
Learn more:
