Power & energy applications
Product Updates
Corporate News
Dewesoft Events
Top authors
Download Dewesoft Customer Case Study Booklets
We give you 34 real-life customer stories – check out our booklets with case studies. These stories show how our customers did their jobs with a little help from some Dewesoft friends.
Each of the four booklets is focusing on a specific industry or field of applications: Power & Energy, Aerospace, Automotive, and Monitoring.
Dewesoft case studies cover
Download power & energy case study booklet
Dewesoft power and energy case studies
It’s all about power, grid, reactors, generators, engines, and appliances. Switch and vibration testing on high-voltage reactor, biogas engine testing, DAQ integration on testbed, power inverter testing, electric household appliance testing, diesel generator certification, and performance and powertrain measurements on marine vehicles.
High voltage reactorVibration Test on High-Voltage ReactorLearn how vibration measurement with a power analysis solution is used to identify the differences in the level of vibrations on a high-voltage reactor.Terna SpA high-voltage switch testing case studyHigh-Voltage Switch Testing With SynchronizerLearn how Dewesoft DAQ system and Power Analysis solution worked for checking the switching function of an old synchronous high-voltage circuit breaker.Biogas Engine Testing and Parameter OptimizationBiogas Engine Testing and Parameter OptimizationSee how Power UP GmbH uses the Dewesoft combustion engine analyzer solution is used for biogas engine testing and parameter optimization.Testbed control deskDewesoft Data Acquisition (DAQ) Integration with KS Tornado TestbedLearn how Elin Motoren continuously got the vibration data from Dewesoft hardware and software into the Tornado testbeds via TCP/IP by a Dewesoft plugin.Electrical power measurement on invertersTesting Power Inverters and Motor Terminal IssuesLearn how our power analyzers with high bandwidth voltage and current measurements are used to troubleshoot electric motor and inverter terminal issues.Household appliance testingElectric Household Appliance TestingLearn how BSH is utilizing our DAQ systems for voltage, current, and temperature measurements to test household appliances and perform power analysis.Diesel generator set with engineersISO 8528 Certification of Diesel Generators: Noise, Vibration, and Temperature MeasurementsDewesoft data acquisition systems are used to measure diesel generators for ISO 8528-1:2005 certification standards for sound, vibration, and temperature.Alfrastreet marine elctric boat perfomrance testingPerformance Testing and Measurement on Electric BoatsDewesoft power analyzer & data acquisition system was used for performance testing and measurement of Alfastreet Marine electric boat. See the case study.Quadrofoil electric powertrain measurement on hydrofoilElectric Powertrain Measurement on HydrofoilDewesoft set up the measurement of both the DC and the AC part of the Q2 powertrain to measure the efficiency and quality of power conversion of the brushless motor power inverter.
Aerospace applications
Download aerospace case study booklet
Dewesoft aerospace case studies
Fly into space with NASA, ESA, ISRO, DCTA... Structural testing of a rocket nose cone, vibration monitoring on crawler core systems, DAQ and control on launcher booster test bench, performance measurement on hybrid rocket engine, RPS for telemetry processing station, and spaceplane TPS fitting and bonding control.
Propulsion system testingLarge Scale Aerospace Structural Testing for Indian Space Research OrganizationLarge Dewesoft 2264 channel signal conditioning and data acquisition system is used at the structural test facility in Indian Space Research Organization.ISRO IndiaIntegrated Signal Conditioner for Aerospace Propulsion ResearchLearn how ISRO replaced its outdated measurement system with a precision DAQ system for mission-critical applications in aerospace research. Sine processingStructural Testing of Rocket Nose Cone Using Sine ProcessingBrazilian space institute DCTA is using Dewesoft sine processing solution to perform structural dynamic test of rocket nose. Read case study to learn more.Crawler transporter in actionStructural Vibration Monitoring on the NASA's Crawler Transporter Core SystemsLearn how Dewesoft replaced old DAQs for vibration monitoring on NASA's Crawler Transporter core systems that require precise time synchronization.Ariane 6 motor testRocket Engine Test on the ESA's Test Bench For Large Solid Propellant BoostersDewesoft data acquisition and control systems were used on the test bench for testing ARIANE VI rocket propellant boosters. Read the entire case study.SL 2 rocket engine testMeasuring the Performance of a Hybrid Rocket EngineSee how company Spacelink tested and validated the new SL-2 hybrid rocket engine propulsion system using the Dewesoft data acquisition (DAQ) systems.SLS rocket at nightNASA PCM Telemetry Processing StationDewesoft and NASA have developed a modern real-time telemetry system capable of monitoring several hundred thousand parameters in real-time.Dream chaser in flightSpaceplane Thermal Protection System (TPS) Fitting and Bonding ControlSee how Dewesoft data acquisition systems are used to perform fitting and bonding control of the thermal protection system on the Dream Chaser space plane.
Automotive applications
Download automotive case study booklet
Dewesoft automotive case studies
All kinds of vehicles, cars, buses, tractors, race cars… Durability and road load measurement, combustion analysis and performance tuning, race car temperature measurement, airbag ECU bracket inertance measurement, car seat crash testing, brake direction stability testing, pulling sport tractor performance tuning, analysis of engine noise transfer path, tire noise coast-by measurement, exhaust noise testing, component electrical testing, and brake pressure test.
Road Load Data acquisition on rugged road environmentRoad Load Data Acquisition and Vehicle Durability Testing in Extreme EnvironmentFind out more about the Dewesoft road load DAQ system with CAN FD and Kistler’s KiRoad support for the full vehicle, durability, and safety testing.BMW M5 Hurricane performance tunningCombustion Analysis and Car Performance Tuning of BMW M5 HurricaneMeasurement technology from Dewesoft helped tune the engine of the BMW M5 Hurricane sports sedan to reach over 1000 hp and set a world speed record.Alpine BourgesTemperature Measurement on a Racing CarDewesoft temperature data loggers and OPTRIS infrared cameras are used to keep the state-of-the-art race car cool to ensure optimum performance and safety.Airbags inside carAirbag ECU Bracket Inertance MeasurementLearn how our data acquisition is used for airbag ECU bracket inertance measurement by detecting the acceleration signal of the airbag impact sensor.Car crash test dummyCar Seat Crash Test With a CatapultLearn more about car seat crash tests with dummies. The results are used in the automotive & aerospace industry to evaluate seat behavior during an impact.DewesoftX polygon test interfaceDirection Stability Test of a Braking VehicleIn this article, you will find more about measuring the braking performance of the vehicle, using the Dewesoft X Brake test plugin and Polygon plugin.Tractor pulling sportPerformance Tuning in Tractor Pulling SportBy collecting data over a time span of just 1 minute the high-speed data provides a lot of useful information to optimize the tractor engine.Operational transfer path measurementsOperational Transfer Path Measurements and AnalysisLearn how Dewesoft DAQ vibration enabled Elaphe to address the NVH issues and to evaluate and eliminate powertrain contributions to the cabin noise.The test vehicelCoast-by Method for Measurement of Tire Noise According to ECE R117Learn how the Dewesoft solution was used to perform coast-by noise measurements. The system can perform a tire noise test according to the regulations.Formula student Aixtreme racing teamFormula Student Race Car Exhaust Noise TestingSee how the Dewesoft team performed exhaust noise testing and calculated vehicle RPMs based on the sound measurements at the Formula Student racing event.Melecs factory coverElectrical Testing of Automotive ComponentsLearn how a Dewesoft DAQ system has helped Melecs with automated testing and provided a flexible solution for electrical testing of automotive components.Pressure curve in DewesoftXBrake Test Pressure Measurement on BusesThe brake system might be the most important and vulnerable system in the vehicle. Learn more about the brake system testing and analysis in this article.
Monitoring applications
Download monitoring case study booklet
Dewesoft monitoring case studies
Know the long-term perspective - noise, vibration, structural health, or machine condition monitoring. Monitoring of construction noise and vibration, bridge machinery condition, remote turbine monitoring, structural health monitoring of historical buildings, bridges, viaducts, or jetties.
Abu Dhabi global market structrual monitoringConstruction Noise and Vibration MonitoringLearn how the consulting company ACTS set up a Dewesoft monitoring system to ensure there wasn't excessive sound or vibration due to ongoing construction.Chaban-Delmas BridgeMachine Condition Monitoring on Chaban-Delmas BridgeTo increase the quality of predictive maintenance, our customer installed vibration sensors to monitor the kinematic chain and pulleys of the bridge.Lardello geothermal powerplant modelRemote Turbine Monitoring at Geothermal Power PlantLearn how Dewesoft data acquisition systems are used to perform remote turbine monitoring on a geothermal power plant site in Lardelo, Italy.Uraya viaduct Saudi ArabiaStructural Health Monitoring of the Railway ViaductA railroad bridge in Saudi Arabia was observed for around 80 hours to evaluate its structural health with the monitoring system based on Dewesoft integrated sensing devices.Bridge structural monitroing Iolite 3xMEMSStructural Health Monitoring With MEMS AccelerometersLearn how Dewesoft's new IOLITE MEMS accelerometer technology is used for a long term and permanent structural health monitoring of bridges and buildings.Vado Ligure aerial view on Google EarthOperational Modal Analysis (OMA) and Long-Term Structural Monitoring of a Jetty StructureLearn how Operational Modal Analysis & Long-Term Structural Monitoring are vital to understand and optimize the dynamic behavior on a jetty structure.
