1. Comprehensive and user-friendly DAQ software: DewesoftX
Product Updates
Corporate News
Dewesoft Events
Top authors
What Makes Dewesoft the Best DAQ Solution?
When it comes to data acquisition (DAQ) measurement systems, professionals across industries seek reliability, precision, and innovation. Dewesoft has emerged as a global leader in the DAQ space, offering cutting-edge software and hardware that meet the diverse needs of engineers, researchers, and technicians. But what truly sets Dewesoft data acquisition systems apart? Let’s explore the key factors that make Dewesoft DAQ the best solution today.
Dewesoft’s flagship software, DewesoftX, is at the heart of its DAQ solutions. Designed with user experience in mind, DewesoftX combines powerful features with an intuitive interface.
  • Ease of use: DewesoftX data acquisition software offers drag-and-drop functionality, unlimited, customizable display screens, and an intuitive graphical user interface.
  • Multi-domain measurements: DewesoftX records analog signals like temperature, pressure, vibration, strain, voltage, and current. In addition, it records digital counters and encoders, video camera outputs, GNSS/GPS, IMU, digital bus data from CAN, CAN FD, ARINC, 1553, PCM telemetry, radiometric data from IR cameras, and much more. All signals are recorded synchronously regardless of their sampling speeds and update rates.
  • Real-time monitoring: Advanced visualization tools, such as strip charts, scopes, FFT graphs, and analog and digital meters, allow users to monitor and analyze data in real-time effortlessly.
  • Post-mission analysis: Data can be processed during and after recording using built-in mathematical and engineering tools.
  • Extensibility: the base package of DewesoftX is included at no charge with all Dewesoft instruments. It can be extended with various plugins that provide additional capabilities for specific applications. These include sine processing, modal analysis, combustion analysis, electric motor efficiency, balancing, torsional and rotational vibration, PCM telemetry input, and more.
These features make DewesoftX a robust tool for seasoned professionals and accessible for those new to DAQ systems.
2. High-quality DAQ hardware for every application
Dewesoft’s hardware portfolio is as impressive as its software. Built for precision and durability, its devices serve industries including automotive, aerospace, energy, transportation, civil engineering, structural analysis, condition monitoring, and more.
  • SIRIUS DAQ systems: SIRIUS data acquisition systems provide the most precise and accurate measurements due to their extraordinarily high dynamic range and bandwidth. They are available in several form factors, including PC-connected modules, stand-alone portable instruments, and rack-mounting systems.
  • KRYPTON modules: Compact, rugged, and highly reliable, these modules are ideal for harsh environments. Single- and multi-channel KRYPTON modules daisy-chain via a single EtherCAT cable.
  • IOLITE modules: Similar to KRYPTON in architecture, these single- and multi-channel modules are designed for industrial environments and monitoring applications.
  • OBSIDIAN data loggers: A whole new kind of instrument, OBSIDIAN uses embedded processing for unmatched long-term stability, even under the most challenging recording conditions. Made to log data for weeks and months at a time without intervention. Includes a control app for smartphones and tablets.
This diverse, extensible product lineup ensures that Dewesoft can meet the demands of any project, no matter the complexity.
3. Essential DAQ technologies
  • Analog to digital converters: Dewesoft systems have several high-performance sampling subsystems, including patented DualCoreADC technology that employs two high-resolution 24-bit ADCs per channel, resulting in a dynamic range better than 150 dB. Even higher bandwidth and overall performance are available with Dewesoft’s Hybrid ADC technology, which provides sampling up to 15 MS/s per channel and 5 MHz bandwidth.
  • Anti-aliasing filtering (AAF): AAF is highly recommended to prevent false or “alias” signals resulting from sampling too slowly compared to the signal bandwidth. Anti-aliasing filtering is included in virtually all Dewesoft systems.
  • Signal conditioning: These are the essential interfaces between a broad array of sensors and measuring systems. Dewesoft offers signal conditioners for all major sensors, including strain gauges, pressure and force transducers, IEPE and charge accelerometers, thermocouples, RTDs, thermistors, LVDTS, counters, encoders, tachometers, potentiometic sensors, and many more. Nearly every signal conditioner is available with isolation.
  • Isolation: Signal isolation protects against wrong readings, equipment damage, or personal injury when an amplifier’s common mode voltage is exceeded. Most Dewesoft signal conditioners include channel-to-channel isolation, channel-to-ground isolation, or a combination of both, known as galvanic isolation. Isolation is essential when working with high voltages and other sources of electrical potential.
More in-depth information about these advanced technologies:
Dewesoft DAQ technologyDewesoft Data Acquisition Technology ExplainedFind out which are the most important Dewesoft DAQ technologies and learn more about their principle of operation and how they improve the DAQ process.
4. Advanced integration capabilities
Dewesoft stands out for its ability to integrate seamlessly with existing systems. Key features include:
  • Support for multiple protocols: Dewesoft devices and software support communication protocols like RS-232, RS-485, CAN, CAN FD, Ethernet, and EtherCAT.
  • Third-party device compatibility: DewesoftX plugins enable easy integration with external devices such as PLCs, pressure controllers, radar sensors, and LiDAR sensors.
  • IoT and cloud connectivity: Dewesoft’s solutions are future-ready, allowing data to be shared and analyzed via cloud-based platforms.
  • Synchronization capabilities: Dewesoft systems are compatible with several timing and synchronization protocols, including PTP V2 (L2 and L3), IRIG, EtherCAT, etc.
These integration capabilities allow Dewesoft products to be used across a wide array of applications and industries.
5. Scalability and flexibility
One of Dewesoft’s biggest strengths is its scaleability. Whether you’re working on a small research project or a large industrial operation, Dewesoft’s solutions can grow with your needs.
  • Expandable systems: Start small and add more channels or modules as your requirements increase. Dewesoft instruments are available down to a single channel and in multi-channel modules that can be interconnected and synchronized in large networks comprising hundreds or thousands of analog channels and even more digital parameters.
  • Customizable dashboards: Flexible DewesoftX software allows you to tailor your screens to display only the data that matters most to you.
  • Reusable setups: Save and recall configurations to streamline future projects.
  • Integrated ecosystem: Dewesoft products are designed to interconnect and work together seamlessly. Every Dewesoft system can be connected to and synchronized with every other system.
Scalability makes Dewesoft an excellent investment.
6. Exceptional customer support and training
Dewesoft believes in empowering users. The company provides unparalleled customer support and training resources to ensure users get the most out of their solutions.
  • Global support network: With offices and partners worldwide, Dewesoft offers local support wherever you are.
  • Training resources: Access webinars, tutorials, and detailed documentation to master Dewesoft products at Dewesoft Training Portal.
  • Community and Forums: Join a growing community of users who share insights and solutions on Dewesoft Forum.
This commitment to customer success sets Dewesoft apart.
7. Proven performance across multiple industries
Dewesoft solutions have been proven in the most demanding applications across various industries:
  • Automotive: End-of-line testing, NVH (Noise, Vibration, and Harshness) analysis, combustion analysis, electromotor testing, vehicle dynamics, road load testing, pass-by noise testing, and more.
  • Aerospace: telemetry recording, modal analysis, wind tunnel testing, and flight data analysis.
  • Energy: Wind turbine monitoring, solar panel testing, power quality analysis, and grid performance.
  • Industry: Factory automation, condition monitoring, and process monitoring.
  • Transportation: railway car and infrastructure tests.
Dewesoft’s ability to adapt to these diverse fields underscores its position as a market leader.
8. Constant innovation and future-ready solutions
The world of technology evolves rapidly, and Dewesoft keeps pace by investing in research and development.
  • Wireless solutions: Cutting-edge wireless DAQ systems enable remote monitoring and data collection.
  • IoT integration: Dewesoft embraces the Internet of Things and emerging smart technologies, ensuring our products are ready for a more connected future.
  • Sustainability: Dewesoft is committed to reducing its environmental footprint by creating energy-efficient solutions. It starts with designing our manufacturing facilities to be as eco-friendly as possible.
This focus on innovation ensures that Dewesoft users are always ahead of the curve.
Dewesoft’s intuitive software, versatile hardware, seamless integration, and exceptional customer support make it the best DAQ solution. Whether optimizing an industrial process, conducting groundbreaking research, or ensuring safety in critical applications, Dewesoft delivers the tools and support you need to succeed. Experience the Dewesoft difference today and discover why professionals worldwide trust Dewesoft as their go-to DAQ solution.
