Universal amplifier for dynamic and static strain measurements
AB
Alberto Boffi
AL
Alessia Longo
AH
Al Hoge
AB
Aljaž Blažun
BJ
Bernard Jerman
Bojan Čontala
CS
Carsten Stjernfelt
DC
Daniel Colmenares
DF
Dino Florjančič
EB
Emanuele Burgognoni
FB
Franck Beranger
GR
GC
HB
Helmut Behmüller
IB
Iza Burnik
JO
Jaka Ogorevc
JR
Jake Rosenthal
JS
Jernej Sirk
JM
John Miller
KM
Karla Yera Morales
KD
Kayla Day
KS
LW
LS
Loïc Siret
LJ
Luka Jerman
MB
Marco Behmer
MR
Marco Ribichini
MS
ME
Matthew Engquist
ME
Michael Elmerick
NP
Nicolas Phan
OM
Owen Maginity
PF
Patrick Fu
RM
RS
Rupert Schwarz
SA
Samuele Ardizio
SK
Simon Kodrič
SG
Søren Linnet Gjelstrup
TH
Thorsten Hartleb
TV
Tirin Varghese
UK
Urban Kuhar
VP
VS
Vid Selič
WK
Will Kooiker
New SIRIUS UNI Universal Strain Gauge, IEPE, Voltage, RTD, Resistance, and Current Amplifier
SIRIUSi 8xUNI daq system
Can SIRIUS STG amplifier become even more universal? Yes, it can!
The newly released SIRIUS UNI amplifier adds IEPE signal input to the already known STG amplifier. The module is based on the SIRIUS DualCoreADC® technology enabling a high dynamic range (> 160 dB). The amplifier also offers a high voltage range. Improved excitation current accuracy enables constant current supply for quarter bridge applications (2- or 4-wire).
SIRIUSi-8xUNI data acquisition system with universal signal inputs
With the introduction of native IEPE mode, the module supports DC or AC mode input coupling with 0.16 Hz high-pass filter for low ranges (0.3 Hz for 100 V range).
SIRIUS UNI supports both Class 1 and Class 2 TEDS.
The input connector is D-SUB9, the optional connector is a female 10-pin LEMO 2B series (on request 8-pin LEMO-2B, 16-pin LEMO-2B).
Main features
  • Universal input: Voltage, Full/Half/Quarter bridge strain (120 Ω and 350 Ω), constant voltage/current supply, IEPE, Potentiometer, RTD, Resistance, Current (ext. Shunt).
  • High voltage range (up to ±100 V).
  • Better excitation current accuracy.
  • Quarter bridge constant voltage/current supply.
  • High dynamic range.
  • Dual TEDS support (Class 1 & Class 2).
SIRIUS UNI is available in an isolated and differential version. It comes as a single or a rack slice and with UNI+, counter option. For details check the order codes below.
The SIRIUS UNI amplifier supports a bunch of different connection methods for strain gages, selectable in software:
  • Full bridge 6 wire / 4 wire
  • Half bridge 5 wire / 3 wire
  • Quarter bridge 3 wire / 4 wire
Usually the most common is the “constant voltage supply”, furthermore when using the sense lines, cable influences can be cancelled by pressing the “Compensate” button in channel setup.
The “constant current supply” for more demanding applications gives a better sensitivity output even when the cable resistance will change a lot during the measurement due to temperature. So far, the minimum connection method was 3-wire.
SIRIUS UNI amplifier 3-wire connection method
In high temperature strain measurements – on gas turbines, combustion engines, aerospace applications… - the change of lead wire resistance might not be symmetrical. This would indicate strain which physically does not exist. For dynamic strain measurements the static strain value can be removed by selecting AC coupling.
The SIRIUS UNI amplifier comes with a new Quarter Bridge CC (Constant Current) mode, which allows the use of only 2 wires. This AC-coupled resistor measurement is especially needed for rotating machines, where the number of slip ring contacts is limited.
SIRIUS UNI amplifier 2-wire connection (Quarter CC mode) for dynamic strain
SIRIUS UNI amplifier connector pinouts
DSUB9 connector
SIRIUS UNI amplifier DB9 connector pinout
PinNameDescription
1Exc+Excitation +
2In+Input +
3Sns-Sense -
4GNDGround
5R+¼ Bridge/Shunt
6SNS+Sense +
7In-Input -
8Exc-Excitation -
9TEDSTEDS
SIRIUSi 8xUNI front panel
SIRIUSi 8xUNI back panel
LEMO 10-pin connector
SIRIUS UNI amplifier 10-pin LEMO connector pinout
PinNameDescription
1Exc+Excitation +
2Exc-Excitation -
3In+Input +
4In-Input -
5Sns+Sense +
6Sns-Sense -
7DI-CNTDigital I/O, Counter
8TEDSTEDS
9R+/SHUNTResistance / SHUNT
10GNDGround
SIRIUS UNI technical specifications
For full specification about SIRIUS UNI amplifier, please check the SIRIUS technical specifications page.
