New IOLITEi-8xLV Module For Voltage Measurement
IOLITE 8xLV 8-channel voltage input module
The latest product in the IOLITE DAQ family is the isolated 8-channel low voltage module. IOLITEi-8xLV is the perfect choice for a general-purpose voltage input data acquisition module due to high accuracy and high channel-to-channel and channel-to-ground isolation.
IOLITE 8xLV
Standard  IOLITEi-8xLV has two input ranges: ±100 V and ±10 V. Optionally, IOLITEi-8xLV is available with input ranges of ±10 V and ±1 V.
Data is acquired simultaneously from all 8 channels with a sampling rate of up to 20 kS/sec. IOLITEi-8xLV includes an analog anti-aliasing filter with a 26 kHz cut-off frequency (3rd order, Butterworth).
IOLITEi-8xLV is available with two different input connector types: BNC or Terminal block.
The modules are compatible with all IOLITE chassis and system options:
IOLITE R8 and R12 data acquisition systemIOLITE® Rack (R8, R8R, R12)EtherCAT Data Acquisition and Real-Time Control SystemOBSIDIAN R8, R8w, and R12 DAQ systems and data loggersOBSIDIAN®Data logger and embedded data acquisition systemIOLITE Modlar data acquisition devices (DAQ)IOLITE® ModularModular Industrial Data Acquisition (DAQ) Systems
