Flight Test Instrumentation for Helicopter Aerial Refueling: Real-Time Monitoring with the Brazilian Air Force
Primož Rome & Edilson Alexandre Camargo and Domingos José Strafacci
Department of Aerospace Science and Technology (DCTA), Brazilian Air Force – Institute of Aeronautics and Space (IAE), Department of Dynamic Tests (AIE-E)
November 30, 2026
H-36 Caracal connected to the KC-130 Hercules drogue during aerial refueling flight tests (frame from DCTA in-flight video).
Overview
Helicopter aerial refueling from a fixed-wing tanker is one of the most demanding tasks in flight testing. The helicopter flies near the top of its speed envelope, just behind a four-engine turboprop, while its rotor turns a few meters from the refueling hose.
To keep the H-36 Caracal within safe structural limits during the procedure, DCTA's Department of Dynamic Tests needed multi-physics flight test instrumentation that could measure strain, vibration, temperature, position, and speed on board, synchronize all data, and show the results to the flight test team in real time.
The team built the measurement chain around a Dewesoft SIRIUS R2DB data acquisition system and DewesoftX DAQ software, together with rotor-blade telemetry and on-board cameras.
The project ran in four phases, from lab research and modal analysis of the rotor blades to live monitoring of refueling flights with the KC-130 Hercules and, later, the Embraer KC-390 Millennium. Engineers watched the helicopter's structural health live at the two most critical moments, when the probe connects and disconnects, and took home one synchronized dataset per flight for detailed analysis.
Background: helicopter aerial refueling in Brazil
The Brazilian Air Force (Força Aérea Brasileira, FAB) is the largest in the Southern Hemisphere. It is responsible for search and rescue over a territory of more than 8.5 million km² and a vast ocean area, totaling about 22 million km² of land and sea.
Its H-36 Caracal is a twin-engine, long-range tactical transport helicopter built by Helibras (Airbus group). It carries up to 28 troops and is used for combat search and rescue (CSAR), sea rescue, humanitarian aid and troop transport. It was the first helicopter in Latin America fitted with an in-flight refueling probe, a capability that Brazil had previously had only for fighter aircraft.
Range is what makes this matter. The FAB has already used an H-36 for a rescue 270 km beyond Fernando de Noronha, and the crew had to land on the island to refuel along the way. With aerial refueling, called in-flight refueling (REVO, reabastecimento em voo) by the FAB, the helicopter can reach distant emergencies without stopping.
The certification campaigns, coordinated by DCTA, began in December 2018 at Galeão Air Base (Ala 11) in Rio de Janeiro. They continued until the final certification phase ended on 30 October 2020 off the coast of Rio de Janeiro. That campaign included the first fuel transfers from the KC-130 to the H-36 and the simultaneous refueling of two helicopters, with more than 160 contacts between tanker and helicopter.
Brazil became the first South American country to refuel helicopters in flight. In June 2022, the FAB ran its first operational in-flight refueling exercise with helicopters, REVO AR.
Figure 2. H-36 Caracal of the Brazilian Air Force in flight over the Atlantic.
About DCTA, IAE and IPEV
The Department of Aerospace Science and Technology (DCTA) is Brazil's national military research center for aviation and space flight. It reports to the Brazilian Air Force and coordinates all technical and scientific work in the aerospace sector. DCTA has six institutes: ITA, IEAv, IFI, IPEV, DCEA and IAE.
The Institute of Aeronautics and Space (IAE) is based in São José dos Campos, about 90 km from São Paulo. The campus covers more than 2 million m², with 137 buildings, 42 laboratories and more than 3,600 pieces of equipment. Its projects include the S-50 rocket motor and a hypersonic vehicle program.
IAE's Department of Dynamic Tests (AIE-E) handles vibration and shock testing, modal analysis, mass properties, ground burn-out testing, and acoustic characterization. It also performs in-flight tests on helicopters and airplanes for system qualification and certification.
The Flight Test and Research Institute (IPEV) is the DCTA institute responsible for flight testing in the Brazilian Air Force. Also based in São José dos Campos, it conducts development, certification, operational evaluation, and acceptance tests of military aircraft, and trains Brazil's experimental test pilots, flight test engineers, and flight test instrumentation specialists. Its flight test courses are recognized by the Society of Experimental Test Pilots (SETP). IPEV was responsible for REVO project activities, including testing and operating the aircraft throughout the entire H-36 refueling campaign, and had been preparing the campaign's theoretical predictions since 2014.
Figure 3. Institute of Aeronautics and Space (IAE) and DCTA logos.
Stakeholders
  • DCTA / IAE – Department of Dynamic Tests (AIE-E): designed and instrumented the structural monitoring system and led the measurement campaign. Test lead engineer: Edilson Alexandre Camargo, PhD.
  • DCTA / IPEV – Flight Test and Research Institute: responsible for REVO project activities, including testing and operating the aircraft throughout the test campaign. IFI (industrial certification) supported the certification process.
  • Brazilian Air Force squadrons: Gordo Squadron (1st/1st GT) flew the KC-130 Hercules tanker. Falcão (1st/8th GAV) and Puma (3rd/8th GAV) squadrons flew the H-36 Caracal helicopters.
  • Dewesoft supplied the data acquisition hardware and DewesoftX software, and provided application support.
The challenge: keeping the helicopter structurally safe during aerial refueling
During refueling, the H-36's main rotor, blades, gearbox, and tail boom are loaded in ways normal flight does not. Downwash and wake from the tanker, the helicopter's high forward speed, and the shock of the probe hitting the drogue basket all add load. The test team had to know during the flight, not days later, whether any structural parameter was nearing its limit.
DCTA's requirements for the measurement system were:
  • Real-time measurements so the test team could make safety decisions in flight
  • Multiple physical quantities: strain, acceleration, temperature, position, velocity, events and GPS data
  • Easy configuration, including several FFT analyses running at the same time with different settings
  • Data synchronized between the aircraft and all on-board data sources
  • High reliability in a vibrating, space-limited airborne environment
  • Multiple displays with a user-friendly interface for different team members
  • Easy post-flight analysis and export to multiple data formats
A multi-physics flight test problem
This is a multi-physics, multi-rate problem, and it is hard to solve with a single measurement device:
  • Rotating parts: the most important strain data comes from the rotor blades, which spin at high speed. That data has to leave the rotor over wireless telemetry and be merged with data from sensors fixed to the airframe.
  • Frequency content: blade and airframe vibrations are dominated by rotor harmonics. Spotting them live takes FFT, order and harmonic analysis alongside the raw time data.
  • Context: a strain peak means little unless you know what the aircraft was doing at that moment, such as its speed, altitude, heading, distance to the tanker and whether the probe was connected. Video and GNSS data had to share one time base with the structural data.
  • Critical moments: the team identified the connection and disconnection of the refueling hose as the two most important events for structural monitoring. The system had to capture and flag these events without fail.
DCTA also needed a platform it could reuse across other programs, not a one-off custom rig.
The solution: flight test instrumentation built on Dewesoft data acquisition
DCTA built its on-board flight test instrumentation around a Dewesoft SIRIUS R2DB, a portable all-in-one data acquisition system with a built-in display, an Intel Core i7 computer, storage and batteries. With everything in one rugged enclosure, it fit the helicopter cabin and could run on its own for long flights.
The SIRIUS R2DB was fitted with two SIRIUSir-8xACC voltage/IEPE conditioning cards for accelerometers and analog telemetry outputs, and a 100 Hz GNSS receiver for position, velocity, altitude and heading.
Strain on the rotating blades was measured with HBM A-series 350 Ω strain gauges and KMT CTP16-Rotate radio telemetry. The telemetry receiver's analog outputs went straight into the SIRIUS, so blade strain was recorded on the same clock as every other channel.
DewesoftX, with its DSA (Dynamic Signal Analysis) package, handled acquisition, math, FFT, modal analysis, live displays, video, and data storage in a single application.
Figure 4. Dewesoft SIRIUS R2DB all-in-one data acquisition system with SIRIUSir-8xACC cards during lab preparation at IAE.
Equipment list
ComponentDescriptionQty
Dewesoft SIRIUS R2DBPortable all-in-one DAQ with integrated display, Intel Core i7, storage and batteries1
SIRIUSir-8xACC8-channel voltage/IEPE signal conditioning card2 (16 channels)
GNSS receiver (100 Hz)Position, velocity, altitude, heading and precise time1
DewesoftX + DSA optionAcquisition, FFT, modal/OMA, harmonics, visualization and export1
KMT CTP16-Rotate16-channel radio telemetry for rotating applications (3rd party)1
KMT CTP-DEC1616-channel receiver with analog voltage output (3rd party)1
KMT CTP-STG-V32-channel strain gauge modules, full/half/quarter bridge ≥350 Ω (3rd party)as required
B&K 4517-002 accelerometersUniaxial accelerometers on the tail fin and rotor blades2
B&K 4506-B-003 accelerometersTriaxial accelerometers on the rotor and helicopter structure2
HBM A-series strain gauges350 Ω strain gauges on the rotor blades and structure–
PT100 temperature sensorsTemperature measurement–
GoPro HERO13 Black camera and Logitech USB webcamOn-board video recorded in sync with the measurement data in DewesoftX–
B&K 4507-B-004 accelerometersResponse measurement for the lab modal analysis of the rotor blades–
LDS V201 electrodynamic shakerExcitation for the lab modal analysis–
B&K 8230-002 force transducerInput force measurement for the lab modal analysis–
Figure 5. Dewesoft SIRIUS R2DB flight test instrumentation and sensor setup on the H-36 helicopter.
Implementation
DCTA split the project into four phases, each building on the one before.
Phase 1 – research and modal analysis of the rotor blades
The first phase, conducted in the lab, covered supplier selection, blade structure analysis, sensor selection, and equipment testing. We instrumented the rotor blades with dense strain gauge arrays and tested them on a rotating test bench.
The first measurements were modal analyses of the blades to determine their natural frequencies and mode shapes, which served as the reference for everything that followed. For the experimental modal analysis, an LDS V201 electrodynamic shaker excited the blade, a Brüel & Kjær (B&K) 8230-002 force transducer measured the input force, and B&K 4507-B-004 accelerometers measured the response.
Two DewesoftX features were decisive here. First, the team could run several FFT analyses at once, each with its own settings, to look at the same signals at different resolutions and frequency ranges. Second, DewesoftX's modal analysis was easier to set up and adjust than the team's previous tool.
The software allowed us to configure different FFTs. Dewesoft modal analysis is easy to configure and work with the parameters compared with our previous supplier.
Edilson Alexandre Camargo, PhD, Senior Researcher, DCTA
Figure 6. Helicopter rotor blade instrumented with strain gauges.
Figure 7. Rotor blade on the rotating test bench at IAE.
Figure 8. DewesoftX running several FFT analyses at once, each with its own configuration.
Figure 9. Modal analysis setup on the rotor blade.
Figure 10. Modal analysis in DewesoftX: FRFs, complexity plot and stability diagram.
Figure 11. Blade mode shapes identified in DewesoftX.
Phase 2 – flight envelope baseline and operational modal analysis (OMA)
The flight envelope is the range of speed, load factor and altitude in which an aircraft can operate safely. Before flying close to a tanker, DCTA needed a structural baseline of the H-36 at every critical point of that envelope.
The work plan for Phase 2 was:
  1. Install sensors on the helicopter: blades, main gearbox, fuselage and tail
  2. Define the flight plan
  3. Test the equipment
  4. Integrate with the helicopter's own instruments
  5. Run operational modal analysis (OMA) in flight
  6. Measure in flight at all critical conditions in the flight envelope
Blade strain was recorded along the longitudinal and transverse axes for every flight condition, including hover, climb, turns, level flight at different speeds and descent. This provided a clear map of which maneuvers load the blades most. Vibration was measured at key points on the airframe with B&K 4517-002 uniaxial accelerometers on the tail fin and rotor blades and B&K 4506-B-003 triaxial accelerometers on the rotor and helicopter structure, and overall level calculations in DewesoftX were used to estimate how much energy each structural mode carried.
Figure 12. Main dimensions of the H-36 Caracal.
Figure 13. Sensor locations on the H-36 airframe.
Figure 14. Accelerometer installed on the main gearbox.
Figure 15. Strain gauge installation details.
Figure 16. Sensor installation on the tail section.
Figure 17. Strain time history recorded during baseline flights.
Figure 18. Blade strain along the longitudinal axis for each flight condition.
Figure 19. Blade strain along the transverse axis for each flight condition.
Figure 20. Vibration spectra showing the rotor harmonics.
Figure 21. Overall vibration levels used to estimate each mode's energy.
Phase 3 – Real-time flight test monitoring during H-36 / KC-130 aerial refueling
With baselines in place, the system flew on the refueling missions. This phase required real-time safety monitoring, multiple screens, high reliability, a user-friendly interface, and full data synchronization.
DewesoftX showed the live state of the helicopter's structure on one custom dashboard:
  • Strain: RMS values of blade and structural strain channels on analog gauges with green/yellow/red limit zones, so any approach to a limit was obvious at a glance
  • Vibration and harmonics: RMS acceleration and a live FFT that highlights rotor harmonics
  • Temperature: gearbox and structural temperatures
  • Velocity, events and GPS data: a live map of the flight track over the Rio de Janeiro coast, the number of satellites, and a counter of refueling contacts
  • Synchronized video from the tanker's hose and drogue, time-aligned with every data channel
A second screen gave the crew navigation data: velocity, altitude, heading, and distance, shown on compass and altimeter instruments, along with altitude and speed trends for the whole flight.
In a typical mission recorded with the system, DewesoftX logged almost four hours of continuous, synchronized data. That included dozens of probe-and-drogue contacts, flown at around 230 km/h and altitudes between roughly 800 and 1,000 m.
The two critical events, hose connection and disconnection, could be flagged and reviewed immediately. After landing, engineers opened the same file to jump to any contact, check strain and vibration against the video, and export to the formats they needed.
Figure 22. Real-time flight test monitoring dashboard in DewesoftX: strain and acceleration gauges with limit zones, live video, GPS track and FFT.
Figure 23. Navigation screen: heading, altitude, speed, distance and GPS flight track.
Figure 24. Synchronized multi-camera video of the refueling, recorded in DewesoftX.
Figure 25. H-36 Caracal in contact with the KC-130 drogue during the aerial refueling campaign.
Phase 4 – H-36 / KC-390
The fourth phase moved the program to the FAB's new Embraer KC-390 Millennium tanker. Details of this phase are classified.
Figure 26. Embraer KC-390 Millennium tanker used in Phase 4.
Flight test results
  • Structural limits confirmed in flight: strain and vibration on the blades, gearbox and airframe were monitored live throughout the refueling campaign, and the test team could see at any moment how close each parameter was to its limit.
  • Complete baseline across the flight envelope: Phase 2 produced strain and vibration data for every critical flight condition. This is now the reference against which refueling loads are judged.
  • Blade dynamics characterized: lab modal analysis and in-flight OMA identified the blades' natural frequencies and mode shapes and showed how energy is spread across the modes.
  • All data on one time base: rotor-blade telemetry, accelerometers, temperatures, GNSS and video were recorded together so that any event could be traced across all quantities at once.
  • Critical events captured: every connection and disconnection of the probe was recorded with its full structural response.
Benefits for DCTA
  1. Safety decisions during the flight. Live dashboards with limit zones let engineers see a problem as it developed, instead of finding it in post-processing.
  2. One system for every physical quantity. Strain, vibration, temperature, speed, position, events and video in one device and one piece of software, with no separate loggers to synchronize afterward.
  3. Quick, flexible setup. Several FFT configurations, modal analysis and OMA were easy to set up and adjust, which the team rated better than its previous supplier.
  4. Built for flight testing. The all-in-one SIRIUS R2DB, with built-in computer, display and batteries, fit the helicopter cabin and ran reliably through long missions.
  5. Easier analysis after the flight. A single synchronized file with video made it fast to review each contact, and multiple export formats fed DCTA's own analysis tools and reports.
  6. A platform used across programs. DCTA now uses the same Dewesoft hardware and software for other projects (see below).
Beyond the helicopter: other uses at IAE
The refueling program was not DCTA's only use of Dewesoft. At IAE, the same toolset supports two other critical test types:
  • Sine sweep vibration testing. In 2019, Dewesoft engineers visited the IAE laboratory to understand DCTA's needs and developed sine-processing functionality for their application. Before and after each qualification profile, a sine sweep from 5 Hz to 2 kHz records the "signature" of the structure under test. Comparing the two sweeps shows whether anything changed, helping catch damage before it leads to catastrophic failure in acceptance testing.
  • Rocket motor transport monitoring. When the S-50 rocket motor was transported by road, accelerometers on the transport dock and GPS position and speed were recorded to identify where critical shock events occurred. The data was used to tune the dock's suspension.
Figure 27. Sine sweep vibration test at the IAE laboratory.
Figure 28. DCTA and Dewesoft teams at the IAE laboratory.
Figure 29. Dewesoft SIRIUSi-HD-16xACC data acquisition system next to the shaker.
Figure 30. Sine processing configuration in DewesoftX.
Figure 31. Transfer functions from the sine sweep, used as the structure's signature.
Figure 32. Instrumentation on the S-50 rocket motor transport dock.
Figure 33. GPS track of the S-50 transport, colored by speed.
Aerial refueling gives the Brazilian Air Force's H-36 Caracal the range to reach survivors far off Brazil's coast. It also puts heavy loads on the helicopter's structure. With Dewesoft SIRIUS R2DB and DewesoftX, DCTA combined rotor-blade telemetry, accelerometers, temperatures, GNSS, and video into one synchronized system that showed the helicopter's structural state live, at the moment the probe met the drogue.
The phased approach, from lab modal analysis to a flight-envelope baseline to live refueling monitoring, gave DCTA confidence at every step. It also left the team with a flight test instrumentation platform it now uses across its aerospace programs.
Sources: DCTA/IAE presentation "Overcoming the main challenges of instrumentation systems applied to aerospace structures: case study from the Brazilian Air Force" (E. A. Camargo); Brazilian Air Force press releases; helis.com (Dec 2018); Defense-Aerospace.
