Dewesoft X3 SP4 Released
September 25, 2018
We are pleased to announce the release of the new Dewesoft X3 SP4.
The new version of Dewesoft X includes several bug fixes and features, which improve the stability and expand the range of options.
Modal test
Modal test module has gone through a major redesign which results in better and brand new UI and also gains several new functionalities:
Brand new UI
Multiple excitations and responses allowed simultaneously
Easier/faster addition of excitations and responses (new grid)
Multi-select option on excitation/response grids
Redesigned default display
Multiple screens (measure and analyze have different views)
Different colors in transfer function channels (one color prt group)
Easier adding of the input channel (Autofill button)
Easier settings for weighing windows on excitation and response (graphical)
Default decay on the response's window changed to 1% for triggered mode
Rectangular and exponential windows on excitation/response for triggered mode
H2 FRF estimator
PSD, CPSD calculations
FRF geometry VC
Support for the animation of "Visual Groups" from Modal Test
Extended animation to support Complex/Real/Imaginary modes
Manual animation of the structure
Orthogonal representation
Color currently measured points on FRF geometry
Modal circle VC
Input type, damping model and number of points for fitting support
Vector and Matrix numeric visual control
This all-new visual control brings:
Numeric tabular display for vector and matrix data
Upper and lower limit exceeds checking (coloring)
Visual transposing of matrix axes
Device support
New device support:
ECAT-GPS-JUNCTION
KRYPTONi-1xSTG
KRYPTONi-1xLV
KRYPTON-1xCNT
R1DB
Language support
Dewesoft X UI is now available in full Spanish language support.
Other features and improvements
Warning message when the sample rate is adjusted from the TEDS sensor
A warning message is shown when the TEDS chip is connected
Support for pausing TEDS scanning
The system monitor shows the file size
Dewesoft X3 SP4 is a free upgrade for all existing users. The 64- and 32-bit installers can be downloaded from the download center.
Learn more:
