S2-OMA and S2-SHM Now Offer Full Dewesoft (DXD) File Support
May 26, 2025
The latest versions of S2-OMA (Operational Modal Analysis) and S2-SHM (Structural Health Monitoring) software now natively support Dewesoft’s *.dxd file format, enabling users to directly import and analyze data recorded with Dewesoft measurement systems. This direct compatibility removes the need for data conversion, significantly accelerating workflows and maximizing the value of your Dewesoft-acquired data.
S2-OMA: direct Dewesoft data for advanced modal analysis
S2-OMA integrates Dewesoft *.dxd files alongside existing support for formats such as *.tdms, *.lvm, *.csv, and *.txt. Whether your OMA data originates from time or frequency domain measurements, as a Dewesoft user, you can now transition seamlessly from acquisition to analysis without additional steps.
Key features include:
*Native .dxd file support: Load Dewesoft data directly into the platform without conversion.
Guided workflow: Easily navigate from data import to geometry definition and report generation.
Flexible geometry input: Import structure models using *.dxf files for fast setup.
Comprehensive analysis tools: Apply various parametric and non-parametric OMA methods.
Advanced visualization: View animated mode shapes, AutoMAC, CrossMAC, and Complexity plots.
Efficient reporting: Generate fully editable and customizable test reports.
Collaboration-ready: Use the free S2-VIEW viewer to share and interact with S2-OMA results based on Dewesoft data.
S2-SHM: structural health monitoring powered by Dewesoft data
With full support for Dewesoft *.dxd files, S2-SHM enables a seamless path from real-world measurements to health assessment—no file conversion or data restructuring needed.
Dewesoft integration within S2-SHM enables:
Automated processing of Dewesoft data: Instantly apply vibration data to detect structural health changes.
Continuous condition tracking: Monitor natural frequencies, damping ratios, and mode shapes over time.
Damage and anomaly detection: Leverage advanced pattern recognition for early warning insights.
Tensile load monitoring: Analyze tie rods and cables using non-invasive vibration methods.
Unified data management: Handle static and dynamic datasets within a single platform.
By directly applying Dewesoft *.dxd files, S2-OMA and S2-SHM enable faster, easier, and more powerful extraction of insights from your measurement systems, transforming raw data into actionable results without delay.
