Vehicle Dynamics Testing Using Dewesoft VTS
November 1, 2018
Introduction
In recent years, virtual analysis tools have become more and more powerful and predictive, allowing to speed-up of the development process, and to manage the increasing complexity of in-vehicle systems.
Nevertheless, the amount of testing activity is all but decreasing, due to several reasons.
Detailed simulation models require accurate validation, based on reliable experimental data
The refinement of some vehicle attributes still needs the “human touch”, delivered by subjective and objective test and development on physical prototypes
The development and validation of advanced driving functions (ADAS, autonomous driving) still require extensive real-world test In this context, in an extremely competitive global market, the testing process must be extremely efficient, time- and cost-effective.
Overall quality of the measurement
Compliance and reproducibility of the test execution
Data accuracy: sensors and acquisition system
Cost efficiency
Preparation time: easy vehicle sensor setup and DAQ system configuration
Actual test time: optimize the use of the time spent on the test track or on a test rig
Vehicle dynamics plugin
Dewesoft Vehicle dynamics plugin is designed to carry on the pre-processing of the raw signals in accordance with the requirements of ISO standards for vehicle dynamics objective data analysis.
All the settings can be managed in Dewesoft setup. Main features:
Management of the coordinate system
Filters
Compensation of sensor position effect
Compensation of g-force effect
It also provides a catalog of test maneuvers for objective assessment of vehicle dynamics behavior, based on ISO standards: for each kind of test, validation criteria and other objective parameters are calculated and made available as calculated channels in the measurement files.
Vehicle test suite
To achieve the highest productivity on the test track with the DewesoftX Vehicle Dynamics plugin, Leane international developed the application VTS
An easy-to-use driver interface for Dewesoft systems
Support for the Dewesoft Vehicle Dynamics plugin
Management of vehicle data and sensor coordinates data
International standards or custom test procedures
Dewesoft integrated into the VTS measurement panel
Quick look display of the main parameters and execution check
Automatic test file naming and storing in a custom folder structure
Data overlay and statistics from multiple test runs
Test report capability
Modular architecture for easy extension and further customization
The Leane VTS application manages the configuration parameters of each type of test:
Info: basic information about the test
Measurement: sample rate, Dewesoft screen ID and other measurement settings
Trigger conditions
Execution conditions, e.g. the nominal speed or steer frequency, and their typical or allowed values.
Validation condition: validation parameters and their thresholds used in the validation check
The user can edit and store the default configuration of each type of test, including pre-defined values of the execution parameters and the threshold for the validation parameters.
The test driver needs just to select the test session and the test maneuver to be performed.
Then VTS suggests the pre-defined values to the test driver, who can select these values from the measurement panel according to the test plan, with no need to open the Dewesoft setup: one touch is enough, as VTS set everything in the Vehicle Dynamics plugin via DCOM interface.
All the main functions are available with just a single touch:
Start/stop storing
Test setup • Test analysis
Save/cancel the test file
| Test type | Ref. standard |
| Steady-state cornering | ISO 4138 |
| Step steer input | ISO 7401 |
| Step steer non-linear | Based on ISO 7401 |
| On center sinus steer | ISO 13674-1 |
| Pseudo Random Steer | ISO 7401 / ISO TR-8726 |
| Pulse Input Method | ISO 17288-2 |
| Slowly increasing steer | ECE 13H |
| Sine with dwell | ECE 13H |
| More test manoeuvers under development | |
The new Vehicle Dynamics plugin is now available in Dewesoft to manage all the essential tasks related to objective vehicle dynamics testing, according to the main international standards.
The VTS application by Leane and Dewesoft allows for achieving the highest productivity, thanks to an easy-to-use customizable user interface that provides the user with seamless access to the plugin settings and the results.
